- KpackpackkelleyExplorer IIWhats the full model number ?
- dlutzExplorerSays code four is overcrank. Says, logic: controller unable to sense genset frequency after 30 secs of holding the switch. I never get a code if just hold the start switch for several seconds to try a start.
- wa8yxmExplorer IIIChecked the manual. 4 is not a valid code. There a 2, and a 3 and a whole bunch of others but no 4 or 44 or 22. om the manual.
Try again, it says if you get 3 blinks, (or perhaps this applies to 4 as well) touch the stop button again for the next digit. - dlutzExplorerBlinks four times. I held the switch down as it says in the manual. This is the only code i can get. I've bypassed the oil shut down switch and still no go??
- 1492ModeratorMoved from Forum Technical Support
- Mr__SteveExplorerCheck your manual for the codes that your gen is giving you. it will give you an idea of issue, could be low oil, etc.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
