- CharlesinGAExplorerJust watched a Youtube video about this on 4000 (and I suppose the 3600LP). The guy described the symptoms as starting fine, running fine, suddenly shutting down, and later starting up fine.
He claims that TOO HIGH of an oil level (within the normal range on the dipstick) was causing it and that many others commented that they too experienced this and that servicing the oil to just above the ADD mark solved the problem.
https://youtu.be/vzXDlln8aUw
Another video said it was the fuel pump. You can test the pump/filter by taking the line at the carb off and putting it in a container and pushing STOP and this will operate the pump to prime the carb. If you don't get good flow, you may have pump problems, assuming you have a quarter tank or more of fuel in the RV fuel tank.
https://youtu.be/U72Zmk0BF-o
Charles
Charles - GdlowExplorer
Jerseydevil wrote:
Starts and runs for hour, then stalls.
Have plenty of gas in tank. Oil level good.
440 hours in 2006 year.
Thoughts?
There is a video on youtube that shows a guy saying that the way he corrected that is to make sure the oil was not up to the top of his Dipstick as his feeling is that the dipstick is not the right size. I tried that and I can tell you that it helped me...
When I changed my oil it was always taking more that the "required" two quarts to hit the full line..I now only put in the two quarts... Matt_Colie wrote:
Devil,
I have serviced many Onans, but I do not recall an Indiana model. This means that I can't even guess what your issue is, and that is unfortunate. Better still, there is an engine designation on the tag, that will identify the unit without question.
Matt
Onan Distributor is or was MECO(Mcdonald Equipment Company) of Elkhart, Indiana. They installed stickers on all the Onans supplied to OEM's that stated WHO the Distributor Service center is in Elkhart. They are all built out of state, I believe in Wisconsin or Minnesota. Doug- JerseydevilExplorer
Matt_Colie wrote:
Devil,
Matt
Label on lower left is Onan Indiana, maybe where it was made. Looked further and it's 4000 microquiet. - JerseydevilExplorerIt's a Onan 4000 Microquiet.
Actually ran it again last night for about 4 hours and it did not stall.
Maybe fuel? But had it running a few times already. Will check pump and filter.
Thanks all. - justALnowExplorerI had a 5500 Onan in a 2007 toy hauler and it did that. It was the fuel pump... after it cooled off, it would run again.
- MrWizardModeratorOdds are spell check auto corrected
And it's supposed to be "Industrial"
Unless it's supposed to be "inverter" model
Like Matt said need the model# from the name plate data - Matt_ColieExplorer IIDevil,
Matt - jkwilsonExplorer IIIWhat makes it run again? Time, or will it start right back up?
Two simplest checks are fuel filter and vent on fuel system.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
