CharlesinGA
Aug 09, 2020Explorer
Just watched a Youtube video about this on 4000 (and I suppose the 3600LP). The guy described the symptoms as starting fine, running fine, suddenly shutting down, and later starting up fine.
He claims that TOO HIGH of an oil level (within the normal range on the dipstick) was causing it and that many others commented that they too experienced this and that servicing the oil to just above the ADD mark solved the problem.
https://youtu.be/vzXDlln8aUw
Another video said it was the fuel pump. You can test the pump/filter by taking the line at the carb off and putting it in a container and pushing STOP and this will operate the pump to prime the carb. If you don't get good flow, you may have pump problems, assuming you have a quarter tank or more of fuel in the RV fuel tank.
https://youtu.be/U72Zmk0BF-o
Charles
Charles
Charles
Charles
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
