dougrainer
Mar 02, 2017Nomad
Robert6401 wrote:
I'm pretty sure I had burned out the electric heating element because I turned it on with the tank empty by accident for a little while this past weekend, so I replaced it. But, I am curious about the size difference. You can see the two different elements in the picture. It fit fine, so I installed it and tested it out and it seemed to work fine, but do I need to be concerned about the size difference? Hopefully by using both electric and gas at the same time, we will be able to reduce recovery time enough that it won't be as much of an issue when we go camping this weekend.
WHERE did you get the replacement? Non RV 120 elements are longer. Both Atwood and Suburban state you can run the 120 elements up to 20 minutes dry with no damage. Doug
