McKenziek's avatar
McKenziek
Pinhole in Fridge absorber leaking fluid
So I noticed the carpet getting wet alongside the fridge (Norcold 1200LRIM). I go outside and remove the panel and notice water collecting around the base. At first I thought it was just excessive condensation missing the drain tray.(it was 113 Deg. outside) But upon closer inspection I notice that the absorber has two pin holes and its spraying fluid. The pinhole is so small, the stream at first looked like a spider web. It looks like water and has no odor so I ruled out ammonia. But how can that be? Doesn't the absorber store the ammonia? Another reason why I think its water is there is white, hard, what looks like calcium all over where its dripping. I immediately turned off the fridge because I'm well aware of the problems with fire from this brand. Btw, fridge was working fine, very cold. So, #1 Anybody have this happen? #2 Can the pin holes be patched? #3 Am I looking at a new fridge?
Thread update to add image
https://photos.app.goo.gl/gqDLpBChrweeRLXv6
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: Sep 13, 2021
