pianotuna
Mar 15, 2015Nomad III
Hi,
You would need to have the converter powered before the feed from the generator into the transfer switch. Of course that means the converter won't work on shore power.
You could do this:
On generator
generator : transfer switch : converter : 2nd transfer switch : power distribution center
On shore power
shore power : transfer switch : converter : 2nd transfer switch : power distribution center
On inverter
inverter: 2nd transfer switch : power distribution center
I use a "patch panel" myself but then I prefer manual systems for 120 volt power. My default is to leave the converter disconnected.
The above is only one way to do it. I'm sure there are others.
You could do this:
On generator
On shore power
On inverter
