DHart's avatar
DHart
Please help me get new fridge cooling better...
We just picked up our 2016 30' Airstream Serenity with 8 cu ft Dometic Gas/AC fridge.
The coach is parked outside our home while I am doing the test of the new fridge operation.
Here is the scenario:
-Outside temp is around 100 degrees daytime, down to 85 or so at night.
-Temp in the parked trailer (all windows open) is around 100 degrees daytime, 85 night tme.
-Fridge is empty
-Cooling setting is on HIGH (Coldest)
Empty fridge has been running on GAS, on HIGH, for 24 hours. Freezer temp is 16 degrees. Seems good to me! Fridge temp is 45 degrees in mid morning. Not so great.
So, early afternoon I switched over to running it on AC. Now, freezer temp is still 16 degrees, but fridge is at 52 degrees. (During the afternoon, the dropping sun has been beating on the fridge side of the trailer.)
The fridge side of the trailer is facing west, with hot western sun hitting that side of the coach all afternoon.
Obviously, we are not occupying the trailer. It is parked beside the house. And the heat of the environment and temps inside the trailer cannot be helping the fridge do its job at all. And the fact that the fridge is empty... may be a factor as well?
Considering all this, does it sound like our fridge is doing its job as best as can be expected, or should it be cooling the refrigerator section a LOT better than it is?
Freezer performance looks great. Fridge performance is really causing us some concern, but we're not sure how much the environmental factors are influencing the performance.
What should/can I do to improve the cooling of the fridge. Would just filling the fridge with pre-cooled stuff and running the AC in the coach to lower the inside temps in the coach make all the difference to bring the fridge temp down to mid 30's?
