time2roll wrote:
80 psi is the max pressure according to plumbing code. More like 50 to 65 psi is normal. The T&P valve at 125psi is there to prevent tank rupture not to regulate pressure to code. The air bubble in the water heater is not reliable and one more maintenance headache. The accumulator can take the place of the tank air bubble on a permanent basis.
Yes the valve or a fitting could be weak. The spike in pressure can still exist and exasperate the issue.
Not sure why such resistance to the accumulator as a permanent solution.
So who uses 100+ psi to blow out the water when winterizing?
Accumulator in this case most likely is not the real "fix" which is why the "resistance".
Accumulator is not REQUIRED to a RV water system to work properly, period.
Adding a accumulator in this case just basically shovels the real problem under the carpet..
The real problem in this case is most likely a FAULTY TOILET VALVE OR CONNECTION TO THE TOILET VALVE..
I KNOW THIS FROM EXPERIENCE..
I mentioned before that myself, I replaced a old toilet with a brand new one and the brand new one while it was fine with my house pressure of 50 PSI, it WAS NOT FINE WITH CAMPGROUND PRESSURE ABOVE 50 PSI.
The water valve in the new toilet was DEFECTIVE, the valve when manufactured is made in two separate parts, internal parts are put in and the two halves are then sonically welded together..
Sonic welding depends on having two pieces in good alignment.. Mine looked like the two halves were slightly misaligned when welded.. That misalignment created a weak spot/ microscopic pin hole in the weld that would seep when the pressure was above my home water well. It NEVER LEAKED AT HOME but yet leaked at the campground.
Drove me nuts to the point I turned off the water to the toilet until I needed to flush it.
This IS the reason I mention that the OP NEEDS TO LOOK AT AND WATCH THE CONNECTION AND TOILET VALVE.
Fix the problem, not mask and hide the problem.. Adding a accumulator is MASKING the problem and a dangerous game you are playing since a defective/bad toilet valve or even plumbing connection could fail down the road.. I would rather IDENTIFY the problem and REPLACE the valve and or plumbing connection now before the OP floods their RV.
Keep in mind that the issue happens after TEN minutes after they purge the pressure. TEN MINUTES. That is a pretty fast ramp up of pressure, water heater would have to be near boiling to pressure up the water that fast and an accumulator is eventually going to go past that tipping point of leaking again.. Eventually Accumulator WILL run out of "cushion" and the pressure overall will still climb (you can only pressure up an accumulator so far and then the cushion of air will not compress much more if any).
Accumulator will not prevent a failing valve from failing it only will DELAY the failure of the leak.. It is not a "fix all"..
I don't know why the resistance to verifying the leaking spot on the toilet and possibly replacing the toilet valve and/or possibly replacing the plumbing connection to the toilet.
