dougrainer
May 03, 2022Nomad
Buckaroo Billy wrote:
So if I use City Water I just leave the valve (bottom picture) where it is to isolate the fresh water talk -correct?
Doesn't it need to be OFF to the tank?
No, your Water Pump has a check valve that isolates City Water from the Fresh tank. Your pic shows the CLEAR line(pink antifreeze still in it) as the egress to your Water Pump to suck and pump your system with antifreeze. To utilize the Fresh Tank, you move the handle to be IN LINE. 90 degrees. If you do not, that clear line will allow air to suck IN and your Water Pump will not be able to pull the water out of the Fresh tank. Doug
