fowlthing
Dec 21, 2020Explorer
popping and stopping on landing gear?
2007 Cedar Creek with venture landing gear. It popped ever so often.. as if a gear or gears have sheared off . It will extend but has no power to lift the camper.
It broke the shear pin on the long shaft between the two legs.. replaced it and it broke again..so I guess something is binding up in the leg gears???? If the gear box was the issue probably wouldn't be strong enough to break the shear pin
Took the motor of and the pin through the shaft is only on one side.. other side broke off.
I know it is a guess... but is the problem most likely the pin broken on the shaft of the gearbox? Or do I need to replace the gearbox completely. Or would you think the gears in the legs. Ran out of time tonight and looking for advice.
New gear box is not that expensive..
