Portable battery charger urgent
shawnofthedead
Hi all,
My motorhome is stranded in a parking lot after someone stole my catalytic converter.
looking for a portable battery charger because I have no access to electricity. Battery is for coach & is a deep cycle marine.
Need approx 10 amps 12volt.
8 REPLIES 8
Grit_dog
Navigator
Navigator
Well a couple of you at least see through the weirdness of the OPs post. Others, 100% gullible. Re-read the original post.
and now if you still donโ€™t understand that itโ€™s bs, consider that the OP never came back to contribute. Maybe that will be enough of a clue.
wise up folks!
Bummer was hoping to hear more from the OPโ€ฆ. His first post was so fun
Flatfive
Our RV has an emergency switch that allows one to start the engine using the house batteries.
Grit_dog
Navigator
Navigator
lol, what a weird way to spam post. Or just a tweaker.  My guess is the latter. No, wait. Not tweaker. Unless you stole your own car converter! Hahaha
Did you wake up with metal shavings in your hair?  Asking for a friend.
Thanks for the laughs
All of your posts have a link for something to sell. Do you have an RV or are you on here selling things?
way2roll
Navigator II
Navigator II
I am not following the correlation between the missing catalytic converter and lack of electricity. While it is true that the MH's engine might help to recharge the batteries, you likely have a generator. You didn't say what kind of MH you have so some of this is a guess. And as Valhalla said, can't you just limp along to a CG and plug in? get a jumpstart to start your genset etc? Get by until a shop can install a new Cat?
valhalla360
Navigator
Navigator
If you have no access to electricity,  a battery charger is of no use.
Why can't you drive the rv? It will be noisy and you may get a warning light but it should run well enough to get to a nearby rv park.
If you really are stuck with no electricity,  getting a solar system or a portable generator are really the only options.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
rowboatreal
For your situation, a portable battery charger with at least 10 amps and 12 volts that works for deep-cycle marine batteries would be ideal.
NOCO Genius10 Smart Charger: This charger can handle 12V deep-cycle batteries and has a 10-amp capacity. Itโ€™s portable and can charge multiple types of batteries, including marine. The NOCO Genius line is known for being robust and easy to use, even in outdoor conditions.
Schumacher SC1281 6/12V Fully Automatic Battery Charger and Engine Starter: This charger delivers 10 amps for battery maintenance and works well for deep-cycle marine batteries. Itโ€™s portable and offers additional engine-starting assistance if needed.
Battery Tender Plus 12V 1.25A: Though it only delivers 1.25 amps, itโ€™s lightweight, compact, and ideal for slower charging while you wait for a more permanent solution. It is compatible with deep-cycle batteries, but it might take longer to charge. snow rider
Portable Solar Charger: If you have no access to power and expect to be stranded for a while, consider a solar panel charger like the Renogy 100W Solar Panel Kit, paired with a charge controller. These are more suited for off-grid situations like a motorhome.
