johnm1's avatar
johnm1
Portable (suitcase) solar "install" question
I've gone back and forth on solar panels on the roof or portable. Well, due to a tight budget, portable is the only way I'm going to get solar for now and it makes sense for me to try it out 1st as we camp in shade a lot.
I'm looking at the 100-160w "suitcase" styles that are out there and the size/brand don't matter for my question ... unless someone has a real concern about a particular brand or company. Some, like Zamp, are not in the running due to cost.
Most of the kits come with a charge controller (which except Zamp is not water proof) and it's mounted to the back of the panel(s). I want to move it to inside the rv nearer the batteries.
- Using alligator clips to the batteries would be a pain in the backside for my setup. What kind of disconnect plug/connector should I use when I set up and take down the panels?
- I have the "Zamp Solar ready" outlet on the outside of the rv. Can I use that? Is it big enough wire for 100-160 watts of solar?
- Do I need to worry about arcing while connecting/disconnecting?
- Should I install a power cut-off on the wire right near the panels? Which one and I assume it should be water-proof?
- No system that I've seen has any fusing/circuit protection. I assume I should? And where does it go ... between the panels and CC or between the CC and the batteries?
Thanks,
John
