Sixfeetofmud's avatar
Sixfeetofmud
Power center upgrade
Hi all,
Just bought a used truck camper and the power center/converter/charger doesn’t work and needs to be replaced. I attached a pic of the details. I am wondering if the Wfco WF-8725 would be a suitable replacement. Specs attached.
***Link Removed***
***Link Removed***
  • i had a old one with 3 glass fuses and one reset button. strait from 1991. I did have to cut the opening a little bigger but it wasn't a big deal. I think I did a post with pictures in the diy forum or the camper forum.
    Steve
  • StirCrazy wrote:
    I used this one for my upgrade.
    https://www.amazon.ca/Progressive-Dynamics-0318-4135-Inteli-Power-Converter/dp/B01EXKUA3E/ref=sr_1_5?keywords=PD+power+centre&qid=1590406796&sr=8-5
    Steve
    Did you also have an allanson D-20-BRA-A ? That PD 4135 looks like a nice unit.
  • wa8yxm's avatar
    wa8yxm
    I too suggest the Progressive Dynamics. Made in the usa (From I'm sad to say mostly imported parts) it is a proven performer and I really like the way it is factory programmed.
    The 4600 series is designed to replace the electroics on your WFCO. you use teh same breaker and fuse panel. but the back part (The "Guts" get replaced.. I'm on my 2nd one. first lasted over 12 years.
  • I used this one for my upgrade.
    Steve
  • WFCO has a poor reputation, find another brand if possible. You can get good advice from Best Converter, have your current model information available when you call.
  • https://www.amazon.ca/photos/share/7cxrkzSI6Rqxz6CL6EJr2EU08RoGpPNhjJ4YZ9Rh9vE
  • https://www.amazon.ca/photos/share/rb5jwvO2GjBKRy3RhaGPtgDZv6KGXAiBfOtFADiKv78
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 26, 2025
