Route_66_Travel's avatar
Jan 18, 2019
Predator 3500 Question
Before I ask my question, I will say I did do a search and couldn't find the answer. I have been using a Predator 3500 to power my RV for some time now and have no complaints. I do not use my Progressive EMS because it detects an open ground, which I understand. After watching some YouTube videos I decided to make a bonding plug so that I could use my EMS.
Using my voltmeter I measured the voltage from ground to either side of the 120 volt outlet and found it to be 60 volts on either side. My question is what side do I wire to ground? The videos all seem to show 120 volts on one side and zero on the other. I am confused because I thought I would see 120 volts on the hot side, which is usually the right side of the plug, and zero on the left, or neutral side. I assume to make a bonding plug I would jumper between the left side of the socket to ground. But since I see 60 volts on the left side of the socket I need to be sure I am not going to damage my generator, hence the question.
Thanks for the help in advance.
