tvfrfireman
Oct 16, 2013Explorer
Old-Biscuit wrote:Thanks for writing. Yes the power light, stow light, in motion light work. Only the raised (red ) light doesn't work. When the antenna goes up, it turns and rotates about 245 degrees and ends up pointing perpendicular to the curb/door side. Then, when I try to operation the rotation feature I get nothing.
Does the 'stow' light come on when down?
Does the 'motion' light come on when raising/lowering etc.?
On backside on control panel are two connections......power cable connection and a control cable connection. Unplug them then plug back in and make sure connection is tight,
You may have damaged the cable connection inside the turret top when you whacked the antenna.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
