IT_Burnout
Oct 01, 2017Explorer
SoundGuy wrote:IT_Burnout wrote:
I didn’t realize it had a built in delay feather.
The 136" delay is designed to protect your A/C compressor.
If I understand correctly the delay is present on every plug in no matter what the load is (Ac is off) correct?
I always make sure and power down as much as possible in the coach trying to get a controlled shutdown on things before we pull the power to move. Just so at the next power up we are pulling as little current as possible when we plug in. Then I power thing up slowly as needed after we are all setup. Just a habit I have got into.
