time2roll
Aug 11, 2021Nomad
Did you inquire with the RV park about the issue? Any chance they were off-line and running a backup generator? I wonder if there was some other line noise in the connection that may have fooled the EMS. Maybe that is not possible.
If you use the bypass I would recommend monitoring the voltage manually.
