Kountryguy
Nov 17, 2018Explorer
Propane Cooktop
I have a 3 burner Suburban cooktop. Is there a way to adjust the flame lower? The way it is now, there is no way to simmer anything.
KCFDCapt wrote:
Try pulling the knob off and look inside the shaft. Some models have an adjustment screw inside the shaft. Use a flat blade screwdriver to adjust the flame while it is at the minimum setting.
