rfloyd99
Mar 05, 2022Explorer
Propane Regulator Issues
I may or may not have a faulty propane regulator on my 2016 TT. I bought the TT new, and have taken several months-long trips over the last six years. We took a long trip last fall, and when I was checking things out preparing for the trip the propane regulator seemed to be acting up. When I filled the propane tanks the problems (refrigerator wouldn't stay lit, stove burner performance was erratic) stopped, and we had no trouble during our month-long journey.
I'm now getting ready for another long trip, and am having similar problems. Since my tanks were both almost empty, I had them filled, and the problems disappeared.
I'm planning to buy a new regulator so I'll have a spare in case the old one fails mid-trip. I have a few questions for anyone out there with more experience:
1. Had no trouble for the first five years of steady use, does it seem reasonable that I'm having trouble now? Do these things fail often?
2. When the tanks are full, the only problem is the stove burner has a lower flame if other things are using propane. Also, even without the WH or refr. on, using a second stove burner causes the flame level on the 1st one to be a little lower. Is that normal? Not a huge problem, but according to what I've read, the regulator should prevent this. Is it more evidence the regulator is failing?
3. In shopping for a new regulator, they range in price from $38 to $70-80 to $100-120. Of course, I'm attracted to the cheap ones, but would like some advice as to whether that could be a mistake.
What say you all?
Thanks!
What say you all?
Thanks!
