TakingThe5th
Jan 07, 2017Explorer
SwanInWA wrote:
The trailer is 14 months old, I was just generalizing. :) We're the second owner. Maybe we're wrong, maybe it is exhaust -- now I'm starting to second guess. It's pretty strong and it only happens when we run the heater.
The heater is now sitting on our dining room table. This is how much it's bugging us! Any advice on what we should look at? I have a Symbion Portable Propane Natural Gas Leak Detector in my Amazon cart ($23). Anyone ever used one of those?
When I had a problem with my SF-30 I discovered that most HVAC guys I spoke with knew these RV furnaces. My point is that you might make some calls and see if you can find someone who can check out your unit.
Option 2 might be to contact a portable Rv repair tech, explain the problem and invite him to re-install the unit.
Option 3 is to spend some time with the unit on your "workbench". Clean the unit, shake out any heavy baked bug stuff from the exchanger and look for holes See if you can rig up a pressure test of the heat exchanger. Maybe use a vacuum cleaner (blowing and/or suction) against the exhaust or intake while blocking the other to see if you can discover a leak. Be mindful of the sail switch and other components so you don't damage them.
Good luck
