aruba5er
Jan 07, 2017Explorer
I would gamble you have a bad heat exchanger: look real hard at every part of it. Years ago I bought a smoke candle. You light it and it makes a ton of non toxic smoke. Then you could see if the heat exchanger is cracked. Might be hard to do on such a small unit. Or force air into the exhaust and see is you have and movement out of the heat tubes. or is the unit pipes sealed well when it's installed. so not getting any exhaust back into the rv?
