Lar_s's avatar
Lar_s
Propane tank switch over
So, on the drivers side tank everything works. When I turn the switch/lever for the passenger side tank, everything but the FURNACE works. Does it take more propane to run the furnace than the hot water heater? Could it be my valve... it does show green when there is fuel in either tank. I'm stumped.
So far I literally have to grab the tanks and make the switch...
  • Lar's wrote:
    Yup, the passenger side has the Red Top Regulator... perhaps that's the problem.
    Thx for the info.
    Due to length of propane line across front of 5vr the 30# Red Top Reg is required....it lowers cylinder supply pressure to 30# and helps prevent propane vapor condensing back into a liquid in the long line.
    The Red Top Reg fail and can limit propane flow BUT the pigtail hose from cylinder to Red Top Reg can be the cause of problems also
    You can swap pigtails and test if passenger side pigtail works on drivers side
    OR just buy new Red Top and pigtail and be done with it.
  • Yup, the passenger side has the Red Top Regulator... perhaps that's the problem.
    Thx for the info.
  • Which side has the 30# Red Top Regulator---drivers or passengers?
    If it is on the side that has issues with propane (furnace) then the 30# Red Top Reg needs replaced
    IF the auto change-over reg is on side that has issues with propane then you are either opening that cylinder valve to fast and tripping 'excess flow device' (close cylinder valve, wait 30 sec and then open it slowly)
    OR
    the pigtail on that cylinder has a faulty 'excess flow device' (replace pigtail hose)
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
