MEXICOWANDERER's avatar
Aug 15, 2018
Proper Wire Terminal For Oriental Terminal Blocks
You've seen them. Center screw with corrugated like flat tab washer beneath. Screw head uses that goofy straight blade phillips combo.
I'm supposed to attach a pin to the largest wire that will fit the pin (14 AWG) then push forty amps through this terminated pregnancy of a connection?
What am I missing? On Meanwell and Megawatt 400 watt power supplies I came off of EACH screw with a hand formed Y copper strand wire with wire strands soldered and had to make a Triple 14 gauge wire to single cable junction in order to get a pair of 10 gauge wires as main power connections. One and a half hours to connect a single feed terminal block output is stupid.
I used the so-called-pins under the nn washer screws. Neat. They clamp down on a 45 degree angle and under high power they are guaranteed to thermally loosen (been there done that in excess of a dozen trials) Tighten the screws reasonably well and the pin flattens.
Dumb and dumber design wouldn't be an issue it there are alternatives. There aren't. Push 40 amps through a single terminal and then touch it. Prepare to have flesh fused to frying pan terminal.
#2 spade by 16-14 AWG would work. Where does a person look for this terminal?
  • Go to hardware store
    Pick up screw
    If it has a combination phillips / straight head it's from Shanghai
    If it has a genuine phillips, torx, flat blade head it's not from China.
    I've used them all and a screw with a torx head is about 100 times easier than the tranquil butterfly combo. Something 'wrong' with not using crummy screws? Or maybe it's my substandard WiHa special screwdrivers? For these far east specials.
    Yeah I took some skin off a finger yesterday
    I have to find torx replacement metric screws that are affordable
    Grumble, Snort, Snap
  • JaxDad
    Did you pick the lock to my place and uncloak the BORG? I stripped a 4/0 THHN cable to get the 12 gauge solid strands. They soldered right to the Megawatt terminal strip. All three feeders are paralleled each polarity. It's a lot of work doing that to the two units.
    ANYTHING YOURS WILL DO
    MY BORG WILL DO BETTER
    Online 24/7 for SEVEN YEARS
    Try having a battery fully charged in float mode then loading it with 35 amps
    What happens?
    Mine stays in float varying not a tenth of a volt while the charger is supplying 35 amps.
    Consumers have been trained whip and chair to be satisfied with inadequate garbage. "It sez smart and that's as good as it getz"
  • JaxDad's avatar
    JaxDad
    An oxy / acetylene torch with a pin point tip and some 1/16” brazing rod will solve that problem.......
    Until you have to take it apart again.
