RJsfishin
Dec 19, 2016Explorer
That type bypass pump doesn't need any bladder tank, let alone a bigger one.
Having said that, mine works great w/ the little bladder tank,.....once I adjuster the bypass correctly.
And having said that, the 4008 is a cheap universal pump that works well for most I guess.
But I have had too many problems w/ mine, like the screws coming loose, until I installed lock buts on 3 of the 4 bolts. Then I had trouble w/ overheating and shutting down when ever using very low water flow. I finally removed the internal thermosistor, and no more problems.
But if I needed a pump, it sure would be a higher quality than the 4008.
