Push-to-Trip Manual Reset
AStinker-
Just wondering why couldn't a guy use one of these
Clicky
in place of a battery cable fuse and also use it as your battery disconnect and kill two birds with one stone?
If it is a bad idea please explain why?
7 REPLIES 7
AStinker-
Thanks everyone, appreciate your input.
Old-Biscuit
I have one for battery cable to 2000W inverter......works great
Car gurus with high end stereo/amp systems use them all the time
westend
I have a Hi-watt breaker to interrupt the wiring from solar module to charge contoller. The circuit breaker is made by Cooper=Bussmann.
'03 F-250 4x4 CC
Larryect
I figured the same thing. My 5th wheel didn't have any battery dissconnect switch installed. So, I Installed a 50A unit for the trailer system and a 150A to my 1000w inverter. Seems to work well. Haven't tested actual overload conditions. Size appropriatly for your wire size.
http://www.amazon.com/gp/product/B0024JOKM4/ref=oh_details_o09_s00_i00?ie=UTF8&psc=1
myredracer
If to replace the mini circuit breakers in the tongue area, that might be a good idea. I don't like that the stock breakers in the tongue area are self-resetting. If you accidentally connect the battery(s) in reverse, it will keep resetting and eventually kill the battery(s) which is what in some friend's TT last year.
Is this where you meant?
GordonThree
should work, but some things to keep in mind:
it's not going to trip as fast as a fuse, or as accurately - so wiring could be damaged depending on the nature of an overload
although you can trip/reset the breaker, it is not designed to be used as a switch, and will wear out faster
robatthelake
Looks like a great Idea to Me. There may be a problem using it as a Switch .
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
