dougrainer
Oct 23, 2021Nomad
This test is NOT foolproof but works most of the time. Light the range stove top burners. Then Run the Furnace, the water heater and refer on LP. At the same time. Watch the Range burners as the various appliances come on. IF the flames on the range burners diminish or go out or pulsate, your LP regulator is bad. While there is an adjustment on the regulator, it is best to replace it. Doug
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
