steveh27
Jun 06, 2021Explorer
Question about solar and my LiFePo4 batteries
In my Class B Xplorer 230XL I have two 100AH LiFePo4 batteries giving me 200 AHs. While I bought them in June 2019 I have not used them until this spring due to getting multiple myeloma, a blood cancer, which ate my hip requiring a partial hip transplant and a stem cell transplant and chemo. In remission now, but it will return.
I have used my RV since mid April without the solar. WHen plugged in my PD4635 worked well and when driving the alternator would charge until my Trimetric battery meter showed 14.4 volts and then charging would shut down. All good. This past week I've tried using my portable 120 watt solar suitcase. I've had this since 2012 and it has worked OK with my previous 105AH lead acid battery. It is rated at 6.67 amps and 21.6 OCV. I did replace the cheap controller with a Solar 30 which seems good. I have used it a lot when I boondocked in FLA during Feb and Mar. I know it is rare to get the max amps but sometimes I did get 6 amps, usually over 5 amps. I've tried it twice recently and only once got 4 amps. I tested it and got 21.33 volts OCV but only 4.2 amps. This was at noon on May 20 with a clear sky but maybe a bit of slight haze.
Yesterday I tried it again for 10 hours. It was a clear sky with some infrequent slight haze. I took readings every hour from the controller and the Trimetric. When starting the Trimetric showed 71% SOC and I got the highest amp input of 4.2 amps which was never reached again. The next 2 hours it was 3.7 amps and then for the next 2 hours was 3-3.6 amps. After that it was under 3 amps. The total collected for the 10 hours was 28 amps, a 2.8 AH average - not good. When I quit the Trimetric showed 86% SOC. The controller and Trimetric usually showed the same AH inputs. The voltage at the controller ranged from 14.6 to 14.2 V. The Trimetric ranged from 13.4 to 13.5 V.
Any ideas as to why I was not able to get closer to the rated 6.67 amps?
