pianotuna
Sep 06, 2017Nomad III
Hi red31,
Slight over charge is fine with a flooded jar, because if it gasses you can top up the electrolyte with distilled water.
You can not "top up" an AGM so I'd always attempt to keep the voltage slightly below the gassing numbers. I.E. do not overcharge an AGM unless you intend to equalize it.
red31 wrote:
is that @ 14.0v or 14.7v? , '14.7'
I'd rather dance on the side of slight overcharge than constant undercharge.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
