carl2591's avatar
carl2591
Mar 04, 2016
question,, which is better when looking at solar panels.??
Higher voltage, ie.. 24 vs 12 or max amps they can produce.
example: I am looking at a panel rated at 195 watt, 24vdc that produces 5.38 amps and another one that is 160 watts, 12vdc that produces 9.8 amps max.
one panel the 195 watt cost $195. the 160 watt cost $300 and is a bit smaller.
not sure how to see the differences in which is the better panel. higher volts or higher amps.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
