BFL13
Oct 26, 2020Explorer II
Not much use for OP yet, but BurbMan can note this does not need a funnel.
https://www.princessauto.com/en/detail/20-litre-water-can/A-p8570798e
It is for potable water. Only thing is it is heavy when full! I have to stand on a chair beside the gravity fill to get the can high enough to pour it in, and it gets lighter as it empties but not fast enough that it is not a strain on you for the first while. Works though!
Of course, you don't have to fill it, but then it is more trips to the water tap to fill the RV. Also you need a short hose to go from the water tap to the can for filling it, depending on where the water tap is.
I have also used a water pump that fits on an electric drill and used that from the RV's inverter, pulling water up from an open bucket. MSW inverter has the drill turn slower (my impression anyway) but it was enough for this job.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
