whitleybobcat's avatar
Jun 19, 2017
radio w/backup camera
I have a 2016 thor chatuea ford e450....radio only works when hooked up to shore power....unit does not word while driving..so backup camera doesn't work...could this be a problem with my house battery....Im a greenhorn!!!! tks
  • Glad to hear it's fixed; those sorts of problems can sometimes be devilishly tricky to find.
    If the shorted wire was one of the control wires for the battery disconnect solenoid, the dead solenoid was quite possibly collateral damage from the shorted wire. Those latching disconnect solenoid switches are definitely not designed to have the coil energized continually.
  • problem fixed.....shorted wire and bad battery disconnect solenoid...thanks for all the help
  • I'd like to thank you all for your input...voltage to battery fm pwr converter good....need to work my way back to converter with pwr off...will keep all informed.
  • Perhaps your house battery master switch is turned off. It's generally a momentary rocker switch near the entrance door; pressing one side connects it, the other disconnects it.
  • Is it possible you have a rocker switch on the dash that switches the radio on/off from chassis battery? My Winnebagos have had this feature.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 25, 2025
