diamonddogdogs's avatar
Oct 18, 2017
radio
We have a 2008 Phaeton. All of a sudden no sound from the radio. You can see it is on, can see the volumn is playing by the little lights flashing but no sound. There is a switch to the drivers left that says "radio" and that is in the on position. Any ideas what happened to the sound? (TV sound is ok). Thanks.
  • Our motorhome has a switch in the bedroom to allow the music to come thru the speakers in there rather than thru the speakers in the dash. Do you have a switch that got pushed and needs to be changed back? It's a rocker switch.
  • Do you hear audio with headphones or from any of the other inputs? I am assuming “radio” means over the air old fashioned broadcast but I understand that the unit as a whole can be refered to as “the radio”.
  • j-d's avatar
    j-d
    Some "car stereo" units will shut their output off if one of the speaker terminals is grounded. Happened to me on an old pickup truck I bought. Radio'd play unless the window was down. Window frame was touching a speaker terminal. Corrected it by spacing the speaker inboard a little.
  • wa8yxm's avatar
    wa8yxm
    No idea what happened to YOUR RV. .only what happened to MINE
    I had issues with the dash radio (I have two radios) Cutting in and out in and out.. Well I spent a bunch of time under the dash saving money on hair cuts (You don't need to cut it when you pull it all out) here is what I found.
    An amplifier.. Ok so it is described in the 20 pounds of owner's manual.. NOT THE PROBLEM
    A relay box (NOT in the bag).. Also not the problem...exactly.
    Well messing with the relay box I pressed on a MOLEX (multi pin) Electrical connector and when I did I heard the SNAP of the latches latching.
    Yup. was not plugged in all the way . Problem solved.
  • DrewE's avatar
    DrewE
    Many possibilities. Maybe a wire came loose going to the speakers. Maybe the fader control on the radio got set all the way in a wrong direction. Maybe the radio itself is broken. Maybe it thinks you're on a bluetooth telephone call (if it has bluetooth).
    I'm guessing the TV sound doesn't go through the radio, maybe just being speakers built into the TV itself. I could be all wrong there.
  • If the radio has a snap on front panel, these can go bad as the tuner is inside. All the bouncing around does a number on them. I bought a new cover piece for mine on Ebay and swapped it out. Fixed the sound.
  • Not familiar with the unit, but if you have a speaker select switch, make sure some destination is selected.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 25, 2026
