Son_of_Norway's avatar
Sep 02, 2018
Re: Use of Star Washers for Ground Connections
Hello; did an internet search but I am still confused. I am grounding two wires together to the frame of my Suburban using a bolt, washer, split ring washer and nut. Questions: Is this sufficient? Is the use of a star washer advisable? In what position on the assembly should the star washer be placed? How many star washers should be used (one for each wire?) What is the general role of the star washer for a ground connection? Thanks for your wisdom.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
