- Bill_SatelliteExplorer II
Big Katuna wrote:
Bill.Satellite wrote:
Let's just say you have an interesting take on improved technology. E/W requires 2 separate antenna/LNB setups so while it's nice to have that option in the trees, it requires additional hardware and setup time. The locals thing only works if you have a mobile account. The 211/Wally series receivers only do auto setup if you buy an antenna designed specifically for Dish use ONLY limiting your future options.
It's all about choices (not necessarily technology). Your choices appear to be exactly right for you.
I’m comparing using a $400 auto carryout dome that gets HD, east west (nice advantage) instead of a $1500 rooftop that I could rarely use where I like to camp. Being tied to DISH is not a negative. They cost less per month, too.
That's not improved technology, that's the fact that Dish is still using the OLDER KU band satellites to broadcast their signals. The domes CAN receive KU band from DISH and DirecTV. DirecTV changed to the new KA band broadcasts which the domes cannot receive. That's not improved DISH technology, that's just luck that DISH has not updated their technology. If they do, that will be the final death blow to the domes or the dome manufacturers will have to update THEIR technology - Dutch_12078Explorer II
Switching my portable tripod mounted DISH 1000.4 dish setup from eastern to western arc or vice versa adds about 2 minutes to my setup time. Two small screws and swap two coax connections for my Hopper w/Sling setup...
DISH also switches locals with a 5 minute chat session or Facebook messaging session.
And the 211/Wally receivers work fine with the Winegard Carryout G3 that's DISH, DTV, and Bell compatible. - Big_KatunaExplorer II
I’m comparing using a $400 auto carryout dome that gets HD, east west (nice advantage) instead of a $1500 rooftop that I could rarely use where I like to camp. Being tied to DISH is not a negative. They cost less per month, too. - Bill_SatelliteExplorer II
mikestock wrote:
The cheapest way to take DirecTV HD on the road is to get a Slimline 3, a tripod to hold it and learn to set it up. I did it this way for years before installing an automatic Winegard on the roof. I still carry a portable setup when I expect to be in a place where trees could be a problem.
For the portable setup,I found that I have the best luck using a legacy LNB, working with a cheap, self powered, meter to find the satellites and then swap over to a SWM, LNB for viewing.
X2. Not for everyone but pretty easy with a bit of practice. - mikestockExplorerThe cheapest way to take DirecTV HD on the road is to get a Slimline 3, a tripod to hold it and learn to set it up. I did it this way for years before installing an automatic Winegard on the roof. I still carry a portable setup when I expect to be in a place where trees could be a problem.
For the portable setup,I found that I have the best luck using a legacy LNB, working with a cheap, self powered, meter to find the satellites and then swap over to a SWM, LNB for viewing. - Bill_SatelliteExplorer IILet's just say you have an interesting take on improved technology. E/W requires 2 separate antenna/LNB setups so while it's nice to have that option in the trees, it requires additional hardware and setup time. The locals thing only works if you have a mobile account. The 211/Wally series receivers only do auto setup if you buy an antenna designed specifically for Dish use ONLY limiting your future options.
It's all about choices (not necessarily technology). Your choices appear to be exactly right for you. - Big_KatunaExplorer II
Other than more recording channels on the Hopper, what other technology does Dish have that DirecTV does not? You would need to compare a Hopper 3 to the new Genie 2 or similar receivers/antennas. Be sure to include how using having to select Eastern Arc or Western Arc satellites (requiring 2 different LNB's) is better than only having 1 centrally located set of satellites.
Resetting your box and changing locals via your app without calling tech support is nice.
Choosing between east or west has meant getting a signal when trees or hills were in the way..
DISH has a Siri like remote now. Does DTV.? I Haven’t used one.
DISH Hopper mates with Alexa. Does DTV? I don’t know.
If you use a 211, there is built in firmware that sets up a auto carryout with HD. - JohnG3Explorer III use the Dish for my RV iPhone app to find the satellites. If I remember correctly it was a whopping $5 one time cost.
- Bill_SatelliteExplorer IIOther than more recording channels on the Hopper, what other technology does Dish have that DirecTV does not? You would need to compare a Hopper 3 to the new Genie 2 or similar receivers/antennas. Be sure to include how using having to select Eastern Arc or Western Arc satellites (requiring 2 different LNB's) is better than only having 1 centrally located set of satellites.
- jodeb720ExplorerSusie,
I did exactly what you want to do.
I had the same receiver, a portable standard definition dis(18" round)
I built my own collaspable tripod out of 1-14" pvc pipe and generally had it working in about 10 minutes or so.
What I got was Standard Definition from Directv.
That being said, Directv is supposed to stop broadcasting in standard definition in April of 2019.
I had a high definition dish and all the other stuff you need for HD but it took up too much space in my trailer.
That being said, I just recently switched to Dish after being with Directv for 15 years.
Channel for channel I'm saving 600 a year (50.00 a month) plus what I didn't expect was the other technology that Directv doesn't have.
If you want more info please feel free to PM me.
Josh
