TC_Z
Jul 07, 2020Explorer
REDUCED ENGINE POWER
I have a 2007 Winn Voyage 38J on a Workhorse W24 chassis, gas 8.1L engine, 78k miles. 3 times in past 5 years I start, I get a REDUCED ENGINE POWER warning and engine feels like running on 2 cylinders. I turn off, start again, all is fine except check engine light is on. The check engine light goes off the next time I start it. The 3rd occurrence was just recently. I bought a code reader, it shows engine codes:
If others say this is just an anomaly I will continue as-is. Otherwise I may consider replacing components just for peace of mind. I don't want to get stuck somewhere and not have reacted to the warning signs!!
Thanks in advance for your feedback...
- P1516 - throttle position sensor
- P2108 - throttle body control motor
