- Dutch_12078Explorer II
kioticoachman wrote:
Dutch_12078 wrote:
Check the area behind and just above the engine battery for the low pressure A/C port. Some years and models have it there. Another spot sometimes used requires pulling the air cleaner to access the port while yet another spot is under the oil fill. If all else fails, you may have to run the lines to find it.
I should have mentioned the place to add R-134 recharge. But you are correct the Low Pressure A/C port IS just above the engine battery. Fairly easy to add A/C Pro recharge if needed. Thanks for taking the time to help to locate the LP A/C Port.
The first thing is to connect the hose and see what the pressure gauge reading is.
Apologize for the misleading assumption. I really don't think I will have to replace the refrigeration/cooling unit at this time.:) Thanks again! KK
Happy to help! :) - DutchmenSportExplorer
larry cad wrote:
"LP" as in "low pressure", not "LP" as in "liquefied petroleum", the stuff in the tank that you use to cook food. Just a bit confusing.
Well, I had to do a lot of reading on exactly what "LP refrigerant" is and I think it is "propane"... the same quality of stuff you cook with. It's flammable. Here's one of the better web sites with information on it about the differences, pros and cons of using this stuff. And by the way ... this was a new one for me too! I'd never heard of this before until the OP made this post.
Click here. - larry_cadExplorer II"LP" as in "low pressure", not "LP" as in "liquefied petroleum", the stuff in the tank that you use to cook food. Just a bit confusing.
- Flute_ManExplorerMine is back by the engine.
- kioticoachmanExplorer
Apologize for the misleading assumption. I really don't think I will have to replace the refrigeration/cooling unit at this time.:) Thanks again! KK - midnightsadieExplorer IIgoggle might show you,and how to charge it.
- Dutch_12078Explorer IICheck the area behind and just above the engine battery for the low pressure A/C port. Some years and models have it there. Another spot sometimes used requires pulling the air cleaner to access the port while yet another spot is under the oil fill. If all else fails, you may have to run the lines to find it.
- CA_TravelerExplorer IIIAbsorption refers do not have a refill port. When it leaks the cooling unit has to be replaced.
- larry_cadExplorer IIIf I understand the questions, I don't believe there is a fill port for the refrigerant.
- LwiddisExplorer IIRefrigerant doesn’t “disappear.” Have you repaired the leak?
