Dometic.. May not be as bad as you think.. Some things to check before you reach for your wallet.
First if the on/off/temp controls et-al are above the top copartment pull that panel straight otu you will find a mulit-wire ribbon cable leading off to who knows were (Well I do as do many others) unplug and re-plug a few ties 3,5,10.
Oh that panel is called "The Eyebrow" you can put it back now.
Now to the other end of that cable A black box likely on the lower left in the OUTSIDE compartment.. Do the same thing on that end.
Inside said box you will find some fuses.... Check them
You may also have a terminal board bottom center in the outside compartment. ore fuses and possible bad traces (This is a basic board AND fixable if you have the skill. I do but will not instruct. NOTE about this board.... IF 120 volt is an option.. it will be there. it's also where the Ice Maker gets power if you got one... Thus caution please.
Now more on that board.
There is a long black or white tube ribbed.. It has a sort of a plug in the end of it.. This is supposed to be "put out" through one of the vent holes in the cover so it DRIPS DRIPS DRIPS on the ground.. alas many fail do do that and if you leave it INSIDE it drips, drips, drips on the terminal board mentioned above.. You can imagine the end result.
Funny note: Took my Dometic in for a recall. Was mentioning the "Many forget" part of the last pargraph when the service tech returned my keys to the service consultant. Service tech says "I always put it out"... he lied.
