- rk911ExplorerRV fridge? residential fridge? lp turned on? lp in tank? plugged in? breakers in? power on?
- bootenExplorerRV fridge not working on gas or Electric.
- Was there a diagnostics thread posted here?
Warranty? - bootenExplorerIt has a warranty on it. We had a RV dealer put in Thursday, it worked good when we got it home now it's warm.
- rk911Explorerdid you check 12v and 120v circuit breakers? power to tbe panel but no cooling?
- bootenExplorerWe checked all the breakers, the fridge has power the fan is running. It's only pulling 3 amps of power on the power panel. The motorhome is setting level.
- stickdogExplorerIs the check light on?
- Old-BiscuitExplorer IIIHow about BRAND/MODEL for starters......
Generic
12V DC to control module backside of fridge?
120V AC to outlet fridge is plugged into?
Fuses on control module not blown...tested not just looked at?
Upper panel lights on...work?
Does it turn ON?
Does it go in 'auto' mode? - MrWizardModeratoryou did not use the battery disconnect did you ?
did you check battery voltage
120v or LP it still has to have good DC voltage for the controls or it won't turn on an cool booten wrote:
3 amps of 120vac sounds normal for the heater. The rest is just the thermodynamic chemical process so the issue would seem to be with the cooling unit itself.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
