down home wrote:
We have a couple of Midland GMRS/FRS radios. We have a couple more somewhere.
The reed switches are cra3p on all of them. Easily damaged with a bit of thumb pressure.
Range is supposedly about 35 miles, with lots of disclaimers. Wife and I tried for range in Indiana. There might have been a few buildings somewhere in the way. A little over a mile was it. In the woods etc don't expect but hundreds of feet, probably.
Considering for a long time 2 meter radios.So much Information/Misinformation is out there.
Prices in a couple of shops over from over $600.00 to over $1,000.00 for Motorolas and some others. Power is limited by small batteries and antennas and frequencies. A better model with larger battery on belt etc is available but cumbersome.VHS is allowed in Canada why not here instead of reserved for marine use? It would be a lot cheaper.
I will spend a couple hundred maybe three hundred for two radios...with range..and reliability if I could identify them.
There surely is someone here with experience not afraid to warranty, so to speak his recommendations. Licenses are not a problem
You do not "need" Motorolas..
You do not need to spend $600-$1000, not sure what shops you are talking about but if you are looking at commercial radio shops, yeah they beat you over the head for their commercial radios.
In the US, VHF covers a considerable range of frequencies that are broken into segments.
Aeronatical is 117-137 Mhz, a sliver between for meteorologic stuff, Ham is 144-148 mhz, 149-150 radio navigation, 153-174 old analog Police/fire Marine, business Band (this is where a business would use) with a cut out for NOAA at 162 mhz broadcasts.
So, in reality, you COULD apply for a VHF BUSINESS Band frequency and use a VHF handy talky like a Baofeng and you CAN get those dirt cheap now days if you wanted to go that route although seems to me that you have a bigger world if you simply get a No Code Tech Ham license.
8W VHF/UHF Baofeng
HERE for $55
SIX PACK OF 4W/1W Baofeng VHF/UHF
HERE for $115 ($20 EACH!!!)
