MEXICOWANDERER
Nov 08, 2018Explorer
Outside of specification volts per hertz is DEATH to an AC generator voltage regulator. So today's voltage regulators established 55 Hz is a minimum generator speed at which the regulator will force field a generator to maintain voltage.
The problem with timer based protection is that it does nothing to protect against underspeed. It is assumption based protection and assumption based protection is as hazardous as assumption based battery state of charge. Configuring a voltage regulator for a larger generator should include the Volts per Hz inherent protection of a voltage regulator design.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 18, 2025
