LittleBill's avatar
LittleBill
Replace Ladder stand off nut
has anyone replaced these? over half of mine are rusted out. I am trying to think of a way to replace all of them without removing the screws in the fiberglass, but I am assuming this is not going to be possible..
link of what i bought
  • I have R&Rd my ladder, and IIRC, the only way to remove those nuts, is from the back, requiring removal of the standoff. Even then, it seemed they were locked in. I didn't need to replace any, and glad of that!
    Jerry
  • pigman1 wrote:
    Not sure which one of those you're concerned about. The Tiffin ladders are backed up by a molded in steel sheet behind the fiberglass, so removing those screws is fine as long as you don't "ham hand" them going back in. Don't power drive.
    A line in your signature with your rig info (brand, model, year) helps responders tailor their comments to your rig.
    its a 2000 chateau sport, but is that the procedure the entire ladder has to come off? there is 0 video's or docs on the replacement procedure
  • Not sure which one of those you're concerned about. The Tiffin ladders are backed up by a molded in steel sheet behind the fiberglass, so removing those screws is fine as long as you don't "ham hand" them going back in. Don't power drive.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
