- 2oldmanExplorer II
Old-Biscuit wrote:
x2. Works fine.
If it requires ANY use YELLOW GAS teflon tape...not the WHITE - Matt_ColieExplorer IIAs an ex-instrument fitter (decades ago), if you are not VERY familiar with using teflon tape, stay away from it. If mis-applied, it can shed shards into the flow stream and these can be a disaster for regulators and valves.
Find the smallest container (tube or other) of a teflon loaded pipe joint sealer (compound) and coat the male threads carefully.
Matt - ScottGNomadOr pipe dope.
- Old-BiscuitExplorer IIIIf it requires ANY use YELLOW GAS teflon tape...not the WHITE
- Assuming it is the flair fitting... no teflon should be used. Pipe threads only.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
