- NOT running and ON and Off will not cause any problems. Just do what the 2nd poster stated. BTW, MOST people do not realize that the residential's do NOT turn off and stay OFF when power is disconnected and reconnected. ANY time the 120 power is applied to the refer/RV, it will come on. To completely turn the refer OFF so it does NOT come on the next time you apply 120 power, you must read the Refer owners manual and it will tell you how to hold certain buttons down for up to 10 seconds to completely keep the refer OFF. Some people might not like the refer to always come ON when 120 power is applied. Doug
- 2oldmanExplorer II
uncle t wrote:
Probably zero. BTW, it's 'refer'.. reefer is the other stuff! lol
Just wondering what effect, if any, does the fact the reefer is powered up and off several times a year. - past-MIdirectorExplorerPut a box of baking soda in the freezer and fresh food compartment. Make sure the doors are cracked open when you store the motor home. Always totally clean and wipe out the fridge out when you're going to store the MH.
Having RV issues? Connect with others who have been in your shoes.24,200 PostsLatest Activity: Feb 18, 2025
