As usual in Tech fprum, the topic went off track and downhill very quickly :)...
danrn wrote:
am concerned about the power usage of the residential frigs. I know they use inverters to power them, but how long can the inverters and batteries maintain the power? What I would like to know is if I don't have a generator, and I am dry camping, should I be concerned about the frig?
Yes, you should be.
To answer "how long" you need to tell how big battery bank you're going to carry - this is easy, and what are you other energy uses - this is more difficult for most people.
10-12 cu.ft 120V frig will draw 90-120 AH per 24 hours, more-less. So with one pair of 6V 225 AH batts, even if you have absolutely no other loads - no lights, no furnace, no nothing - you will have to run a generator the next day, and do this for 3-4 hours every day until the end of your stay.
And is the advantage of the residential frig faster cooling?
Not much. My propane fridge is getting noticeably cold inside in about 3 hours, and starts cycling (i.e. the temperature is reached) in 8 hours or less, didn't measure. For boondocking more than a few days this isn't crucial. Another advantage of a compressor fridge - residential or 12V - it doesn't need to be level to operate.
Having said this, I should tell that I want and will replace it with 12V compressor fridge, because my solar is - hopefully - big enough for that, and I can add one more solar panel. The problem with 12V units is 3-fold:
1) A bit of DIY work. You need to install it, and preferably to add insulation.
2) For people that got used to huge fridges in their homes, 12V units are small - hard to find any larger than 9 cu.ft. Those that fit into the cabinet of most common 6 cu.ft propane frig, will also be ~6 cu.ft., or maybe 7.5 if your cabinet is bigger than usual.
3) More expensive than 120V residential. Though not much more. Low-efficiency off-brand frigs from big box stores are cheap. But I tried to find a 120V frig that fits into my cabinet, and most models are either too wide or too deep. Those that are slim, are usually new models, designed for smaller places of modern urban kitchens, and cost upwards of $1,000 or $1,200. For comparison, 6 cu.ft 12V unit would cost 1,400-1,500 and will likely be more efficient as it won't require inverter (plus, there is no high starting current in 12V Danfoss compressor).
Edit- PS:
I didn't notice you said "if I don't have a generator". Stay with standard LP fridge, this is the easiest. If you still don't want LP, and don't want to have a generator, and don't want any DIY, then the only way is to get a VERY small 12V fridge, there are portable models that need no installation. I would still add a small solar system in this case, there are portable arrays under $300. You might also need to increase the battery bank size to 300-400 AH 12V equivalent.
