ExRocketScienti
Feb 21, 2012Explorer
CapriRacer wrote:ExRocketScientist wrote:
This is exactly the information I would like to put in a chart. For all of the LTs that are readily available in the marketplace with a tread appropriate for trailer use (FastEagle would be a big help in coming up with a good list), find out what the load rating is of an ST tire of the same size (even if not available in the marketplace).
Just doing a quick calculation here -- 1.09 x 3042 = 3315 (rounded down to the nearest pound). At 12% that would be 1.12 x 3042 = 3407 pounds. At 13% 1.13 x 3042 = 3437. So it might be that an LT235/75R16 LRE is a direct replacement for a ST235/80R16 LRE (Goodyear Marathon 3420 lb) if the ST235/75R16 LRE is 13% or more than the LT235/75R16 LRE. But it wouldn't be a replacement for the Towmax that FastEagle uses which is 3520 pounds. That is why having accurate numbers here would help.
CapriRacer -- can we work up a chart?
Ah ...... yeah, but why? There are a ton of LT size possibilities, and I'm hoping you're not going to try to cover all of them.
No, not all of them. There couldn't be more than a dozen in 16" or smaller rims (I'm thinking this should only cover 14", 15", and 16" rims -- 5 or 6 tires in 16", 2 in 15" that I know of. I'll have to work with FastEagle on 14" -- perhaps he may be able to come up with one or two more in the 15").
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
