Byrogie's avatar
Byrogie
Riddle me this, inverter
Xantrex Freedom 2000 watt inverter
Trailer is 50 amp service. 4x6 volt GC2, fat wires.
Hooked up to main trailer power via inverter outlet, extension cord and adapter.
500 watt coffee pot/ 800 watt hair dryer trips inverter outlet. These work fine if plugged directly to the inverter.
All other stuff works fine in trailer, TV, charging phones, ceiling fan, etc.
My ac tester shows good power, but trips inverter outlet when I press GFI test button.
Will eventually hardwire the inverter, will it work properly then?
