Carrera_man
Mar 18, 2015Explorer
RLS7201 wrote:
What you are experiencing is an electromagnetically induced voltage. I had the same problem on my MH when I added LED tail/stop lights. A little resistance between the hot leads and ground will bleed off the induced voltage. I added a 912 incandescent bulb to each side behind the tail lights to bleed of the stray voltage. In my case the stray voltage caused the cruse control and torque convert clutch to malfunction.
Richard
95 Bounder
LED's came with this trailer. Trailer has been sitting plugged in since the end of October. Problem didn't start until last week and only on the right taillight. I would agree with those here if more then one light was effected about a ground or stray voltage. It sure does sound like, as some have commented, that its a problem in the cable going to the truck or the box that cable is connected to. That will be my first place to start.
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
