Medicrn's avatar
Medicrn
RM 2807 fridge question
Switch underneath panel is labeled in parts manual as climate control. What does it do?
  • Helps reduce condensation around the door seal in humid weather.
    It also draws down the battery if you are not on shore power.
  • The "Climate Control" switch controls a 12 volt heat tape behind the metal frame around the refrigerator and freezer doors.......it should only be used if condensation on the frame is noted.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
