scroller95969
Aug 02, 2013Explorer
Roof delamination
I have an area in my rubber roof about 8" in diameter near the back of the roof grey tank vent that has a bubble in it. I made a 1 inch cut in the middle and the top 1/16" - 1/8" of the plywood is delaminating from the underlying plywood. It seems to be dry underneath as far as I can tell by sliding my finger inside. Has never leaked inside. Was thinking about putting some staples in it and then covering the staples with a small amount of Dicor lap sealant and then covering with Eternabond. Another one of my thoughts would be to slice it completely open to check for damage and then laying the roof back down with some kind of adhesive and then covering the slice with Eternabond. Before I do anything else I wanted to run it by you guys to get your opinion. It is a 2004 Tioga class C. Thanks.
Moved to Tech Issues forum from DIY.
