rrt74's avatar
rrt74
Rooftop AC Units
We have a 40' fifth wheel with two older model rooftop AC units, but of them needs to be replaced. Any make & model recommendations would be greatly appreciated. We are full-timers and reside in Florida, so we are in need of a unit that cools exceptionally well.
Thanks!
  • wa8yxm's avatar
    wa8yxm
    No make or model suggestions unless your units are Carrier Air V's
    IF they are carrier Air V's. and IF YOU CAN GET THE ADAPTER KITS
    Coleman makes a replacement rooftop unit that can be adapted to your existing controls (So does Advent Air but I have one of each and like the Coleman better)
    This way you change NOTHING inside the RV.
    Big if on the adapt-a-kit however.
    Otherwise.. Most of them are more or less equivlent though Advent Air is made in China and is a witch when it comes to preventive maintenance.. I've not yet PM'ed my Coleman (it's too new) but from the exterior design I think it's going to be way easier.
    On the Carrier.. when I went to clean the condenser every spring/fall.. I removed screws and other connectors
    On the advent air I have to remove metal tape and bend tabs.. at least till I get around to screwing it......... together (Next cleaning more than likely) .
  • You should be able to order the same thing/size online and will probably find them a lot cheaper than buying them from an rv place, unless they are on sale. Our previous co-hosts wanted to add a 2nd A/C to their already pre-wired bedroom. Dealer wanted $1,200 --- purchased exact same online for $500 and had mobile rv tech install. That was a couple hundred, so still saved around $500. If you are handy, maybe you can re-install replacements yourself.
